gpmcmahan
#1 Posted : Thursday, January 10, 2008 9:07:08 PM(UTC)
gpmcmahan
Repairman said control panel went bad, so we ordered one, installed it, all the buttons work, clock, etc. Only, the oven won't heat up. The oven temp starts at 100 degrees. Doesn't seem to want to go up from there. However, if we cancel and turn on broil HI for just a second, then cancel that and turn the oven back to 350 degrees it will begin to heat up, but takes forever. Only got to 175 in about 15 minutes. What's up!!!! Could the bottom element be bad also? Well, the element was broken, so replaced it with a new one and still the bake element will not get hot. Help!!
Lower GE wall oven won't heat up (Oven Repair (including Ranges and Cooktops))
by scalpeldoc 2/6/2019 11:56:18 AM(UTC)
Samsung Range and Oven Won't Heat Up (Oven Repair (including Ranges and Cooktops))
by neweyess 8/19/2013 5:13:28 AM(UTC)
Kenmore gas oven won't heat up properly (Oven Repair (including Ranges and Cooktops))
by Black Cherry 3/27/2013 11:12:55 AM(UTC)
The oven won't heat up. The pilot is lit and not heating oven (Oven Repair (including Ranges and Cooktops))
by Hazelave.corp 11/21/2012 3:55:15 PM(UTC)
whirlpool oven won't heat up (Oven Repair (including Ranges and Cooktops))
by smeighan 11/19/2012 4:38:18 PM(UTC)
Oven won't heat up but broiler works fine (Oven Repair (including Ranges and Cooktops))
by NJ Mom of 3 11/11/2012 4:42:15 PM(UTC)
Oven won't heat up? element and/or sensor problem?? (Oven Repair (including Ranges and Cooktops))
by renzandjo 7/18/2012 9:26:23 AM(UTC)
kitchenaid oven won't heat up (Oven Repair (including Ranges and Cooktops))
by susanm 6/5/2012 6:29:46 AM(UTC)
Oven won't heat up after self cleaning cycle (Oven Repair (including Ranges and Cooktops))
by ToughTags 2/28/2012 3:15:55 PM(UTC)
Maytag Oven Won't heat up (Oven Repair (including Ranges and Cooktops))
by Petezr 1/25/2012 6:27:38 PM(UTC)
GE Wall Oven Won't heat up (Oven Repair (including Ranges and Cooktops))
by tejyam@hotmail.com 1/17/2012 1:29:54 PM(UTC)
Oven won't heat up, need help! (Oven Repair (including Ranges and Cooktops))
by dogrobber13 8/16/2011 8:09:08 AM(UTC)
by macnchez 7/5/2011 3:19:55 PM(UTC)
Oven won't heat up (Oven Repair (including Ranges and Cooktops))
by Haf 6/12/2011 3:27:40 PM(UTC)
Maytag Gas Oven Won't heat Up (Oven Repair (including Ranges and Cooktops))
by cjklein1 4/22/2011 10:01:07 AM(UTC)
