chelli
#1 Posted : Thursday, January 10, 2008 5:14:49 PM(UTC)
chelli
The washer fills with water then sits still while it goes through the wash cycle (without agitating) then it will drain and when it gets to the spin cycle it just sits there again. Could it be just a belt or something more expensive like a transmission? Help!!!:(
#2 Posted : Thursday, January 10, 2008 5:49:50 PM(UTC)
Originally Posted by: chelli Go to Quoted Post
The washer fills with water then sits still while it goes through the wash cycle (without agitating) then it will drain and when it gets to the spin cycle it just sits there again. :(
Does the motor run?
In order to provide the most accurate advise I need the complete model number of the washer.
dexter
#3 Posted : Friday, January 11, 2008 11:45:36 AM(UTC)
dexter
Of course we'll need the model number to know for sure, but if it's a direct drive model it's probably just the coupler between the motor and transmission that needs replacing. It's an inexpensive part and you can usually tell if that is the problem by tipping the machine up and looking under it. There is usually a small pile of black rubber shavings on the floor under it as well. If you are somewhat handy this is not too difficult a part to replace yourself. As Gene said, the model number will help determine.
110.24622300 direct drive washer wont agitate or spin motor hums (Washer Repair)
by Guest 10/10/2021 7:32:00 PM(UTC)
washer wont agitate or spin (Dishwasher Repair)
by steve2016 4/21/2016 8:12:47 AM(UTC)
my washer wont agitate or spin ULTIMATE CARE ll (Washer Repair)
by ballprez6 12/26/2014 11:12:12 AM(UTC)
GE Profile washer wont agitate or spin, motor will hum (Washer Repair)
by copperman 8/12/2014 4:20:30 PM(UTC)
washer wont agitate or spin (Washer Repair)
by bjsmith7 3/9/2014 7:19:34 PM(UTC)
roper washer wont agitate or spin!!!! (Washer Repair)
by mrbreezio 4/28/2012 12:24:29 AM(UTC)
Kenmore front load washer wont agitate or spin (Washer Repair)
by ebcravens 1/10/2012 2:27:09 PM(UTC)
hotpoint washer wont agitate or spin (Washer Repair)
by bksmith623 10/8/2011 9:14:31 AM(UTC)
GE Washer wont agitate or spin (Washer Repair)
by tinkerbell63 10/4/2011 3:21:59 AM(UTC)
by lpadilla 6/19/2011 10:06:42 AM(UTC)
by mikeyk01 4/19/2011 6:58:18 AM(UTC)
by Chukcharp 1/31/2011 8:57:01 PM(UTC)
Ge Washer Wont Agitate Or Spin (Washer Repair)
by cameo591 11/19/2010 3:31:06 PM(UTC)
washer wont agitate or spin, makes grinding noise (Washer Repair)
by donnascruggs 10/3/2009 9:02:12 AM(UTC)
by jamc0616 9/3/2009 6:03:30 PM(UTC)
