gmerrill
#1 Posted : Monday, August 10, 2009 6:18:05 PM(UTC)
gmerrill
When I plug the ribbon plug from the electrical panel into dispensing button panel it starts to generate ice cubes automatically. I have unplugged fridge in an attempt to re-set anything, still no luck. Help?
#2 Posted : Tuesday, August 11, 2009 5:25:53 PM(UTC)
Check the micro switches (#38A on the diagram). If there is nothing wrong then the problem most likely is a bad power board but there is a small chance for the control board (#38C) to be bad as well.
- The micro switch Part number: AP3959579
- The power board Part number: AP3965513
- The control board Part number: AP3963433
