When I plug the ribbon plug from the electrical panel into dispensing button panel it starts to generate ice cubes automatically. I have unplugged fridge in an attempt to re-set anything, still no luck. Help?
Check the micro switches (#38A on the diagram). If there is nothing wrong then the problem most likely is a bad power board but there is a small chance for the control board (#38C) to be bad as well. - The micro switch Part number: AP3959579
