Prrothead
#1 Posted : Monday, August 10, 2009 10:55:27 AM(UTC)
Prrothead
Hi Folks
My dryer will not run - I have power, I have checked the thermal fuses and they are fine. When I set the timer it runs only if the dryer door switch is in the out position. (As if the door was open and if you push the switch in it stops)
The light works and if you push the switch in the light goes out like it should if the door was closed.
Any Ideas ??
Thank You
magician59
#2 Posted : Monday, August 10, 2009 11:06:37 AM(UTC)
magician59
Check the outlet. You should have 240VAC. There may be a partially tripped breaker. If it's OK, the next thing to do is try it in all the cycles to see if it works in any, all, or none of them. Please post your findings.
Prrothead
#3 Posted : Wednesday, August 12, 2009 9:03:56 AM(UTC)
Prrothead
Hello again and thanks for your help.
I have 240 volts and does not work in any of the cycles.
magician59
#4 Posted : Wednesday, August 12, 2009 9:09:14 AM(UTC)
magician59
Try reversing the wires on the door switch.
Prrothead
#5 Posted : Saturday, August 15, 2009 7:33:20 AM(UTC)
Prrothead
Switching wires did not help and now I have nothing. The light does not come on and the timer does not click any more. I know its something simple to fix it drives me crazy because there is hardly anythng to these things.
Thanks Again
jgluck1977
#6 Posted : Saturday, August 15, 2009 10:01:25 PM(UTC)
jgluck1977
Get a new switch...
Whirlpool Ice Dispenser Auger will not run (Refrigerator & Freezer Repair)
by WhirlpoolDave 4/1/2024 12:44:26 PM(UTC)
Roper washer will not run (Washer Repair)
by Guest 12/10/2023 10:53:47 AM(UTC)
Kenmore Elite Will Not Run (Dishwasher Repair)
by Chris_McGrath 5/29/2019 9:18:57 AM(UTC)
Dryer Will Not Run Unless Knob Is Held (Dryer Repair)
by Dixiedogs99 12/10/2017 5:41:06 PM(UTC)
Maytag Atlantis Will Not Run (Washer Repair)
by Bsktbll 10/28/2017 5:29:38 PM(UTC)
Frigidaire Wine fridge compressor will not run after moving (Refrigerator & Freezer Repair)
by sauteman 10/2/2017 7:37:28 AM(UTC)
Dryer will not run on no heat setting (Dryer Repair)
by rgarris1969 3/11/2017 6:59:15 PM(UTC)
Whirlpool dishwasher will not run (GU1500XTLS2) (Dishwasher Repair)
by mindnmines 3/3/2017 4:47:18 AM(UTC)
Dryer will not run after changing plastic shims (Dryer Repair)
by Craig Lee 1/30/2017 4:09:05 AM(UTC)
Whirlpool washer will not run (Washer Repair)
by gizmobently 8/22/2016 5:07:12 PM(UTC)
Whirlpool Quiet PArtner III Pot/Pan light on and dishwasher will not run (Dishwasher Repair)
by DJ Chaffers 1/2/2016 6:13:21 PM(UTC)
Dryer Will not Run without manual turn of Drum (Dryer Repair)
by Cadman07 9/17/2015 6:58:08 AM(UTC)
normal cycle green light blinking.will not run (Dishwasher Repair)
by wvirnwkr 6/24/2015 4:08:06 AM(UTC)
kitchen aid dishwasher drain motor will not run (Dishwasher Repair)
by phantomjet 4/22/2015 8:17:13 PM(UTC)
Kenmore Elite Dryer will not run for more than a second...have done lots of troublesh (Dryer Repair)
by The_Wizard 11/10/2014 4:39:55 PM(UTC)
