michael0874
#1 Posted : Sunday, August 9, 2009 2:03:57 PM(UTC)
michael0874
I accidently heated up a a bag of chicken wings and it had a small wire on top of the bag. I am assuming arcing occured, cause the bag caught on fire.. doesn't look like any damage was done except that the microwave doesn't turn on. Do i need to replace the microwave or do i ned to replace the fuse?
#2 Posted : Monday, August 10, 2009 1:36:35 PM(UTC)
Most likely the cavity thermal fuse is open. For more accurate advice we need the complete model number of the microwave.
michael0874
#3 Posted : Tuesday, August 11, 2009 3:44:43 PM(UTC)
michael0874
Gene i got ur message the model # is JVM1640WJ 01..If the Thermal fuse is blown, will it be easy to replace. Id rather get that done than go buy another Microwave.. thanks alot:)
#4 Posted : Tuesday, August 11, 2009 7:27:40 PM(UTC)
The thermal fuse is shown as #27 on the diagram. Looks like you have to remove the microwave from the cabinet and remove the outer case and some ducts to gain access to the part.
- The duct thermostat Part number: AP3202548
Guest (4)
