we were useing our stove and all of a sudden we had no power for it. we have check the breakers and all the plugs and can not find the problem with it. nothing will work. does anyone know what we have to replace on it to make it work again
In order to provide the most accurate advise I need the complete model number of the stove.
Best regards. Gene.
that was the model number listed on the stove. we have just found out that the problem was the wall plug in and not the stove itself though.
I'm glad you were able to fix it.
Best regards, Gene.
