manthonyps
#1 Posted : Wednesday, March 7, 2012 11:48:14 AM(UTC)
manthonyps
I have an O'keefe and Merritt stove. I can not locate the model number. I purchased it used. It has a polit-less ignition. I believe that may be the problem. The burners work on demand and the oven comes on when it desires if at all. How do I identify the model number and troubleshoot the problem. Is there a how to repair step by step manual? where do I find it?
Simon / APP Team
#2 Posted : Wednesday, March 7, 2012 5:52:25 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Raise the the cooktop. The model number should be right there.
Post the result.
manthonyps
#3 Posted : Thursday, March 8, 2012 10:32:36 AM(UTC)
manthonyps
I did raise the cook top and there is nothing there. No plate no number, nothing.
Simon / APP Team
#4 Posted : Thursday, March 8, 2012 1:21:21 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Pull the bottom drawer and check the sides.
manthonyps
#5 Posted : Monday, March 12, 2012 8:11:30 AM(UTC)
manthonyps
I found a plate with numbers on the the number is:
36-6042-23/04098-15150704
I believe the model number is 6042 correct?
Simon / APP Team
#6 Posted : Monday, March 12, 2012 8:56:26 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You need to get to the oven ignitor. Take out the bottom cover then the flame shield and observe the ignitor performance. Turn the oven on. If the ignitor glows red - most likely it's bad. Should be bright white. Replace it.
If it's not getting hot, visually inspect it for brakes. Using the multimeter check for continuity between two lead of the ignitor.
Next check for 120v going to the ignitor.
Post results.
The ignitor Part number: AP2150412
manthonyps
#7 Posted : Monday, March 12, 2012 10:35:18 AM(UTC)
manthonyps
I placed the order for the pilotless ignition. where to I find how to replace step by step instructions. It looks very simple however, lifw has taught me to be concerned when things look simple.
Okeefe and Merrit
Oven ignition
Simon / APP Team
#8 Posted : Monday, March 12, 2012 10:57:53 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
It will be hard to find instructions for your model, but here are the universal step by step.
First remove the power to the unit.
With the door partially open pull it straight up of the hinges.
Remove the shelfs and bottom cover.
Remove the flame shield.
Remove two screws holding ignitor.
Splice new ignitor in using wire nuts, provided in the kit.
Reinstall ignitor on the burner.
Turn on the oven and check how it lights. The burner may need cleaning.
Reassemble in revers order.
Post result.
manthonyps
#9 Posted : Friday, March 23, 2012 8:08:45 AM(UTC)
manthonyps
Hello:
I just want to thank you folks for helping find my way through the appliance maze. Because of your assistance I want able to identify the part, purchase and install it. Get this it cost me all of 30.00 dollars. I am am laughing at how something so simple can make me feel so BIG. Thanks again.
Mark
Simon / APP Team
#10 Posted : Friday, March 23, 2012 8:57:49 AM(UTC)
Simon / APP Team
Groups: APP Team
You are very welcome. I'm glad we where able to help you.
