MonicaDove
#1 Posted : Thursday, August 6, 2009 11:03:58 AM(UTC)
MonicaDove
Hi! First, thanks for this website! Lots of great, helpful information for us do it yourselfers.:D
From what I've read, I have a lid switch issue, upon closer inspection, I thought it was my lid switch check...the switch inside that wasn't reacting when the lid switch was engaged. I replaced that, and now, I keep blowing fuses. Does the entire assmembly need to be replaced? or, do I have another problem?
Thanks in advance,
Monica
#2 Posted : Thursday, August 6, 2009 4:25:15 PM(UTC)
Monica,
There are two switches in the lid switch assembly
UserPostedImage
and it is very important to adjust them properly. You can find the complete instructions in the Service manual (page 3-15).
MonicaDove
#3 Posted : Thursday, August 6, 2009 5:07:56 PM(UTC)
MonicaDove
Thanks Gene. It was the lid check switch that I replaced, or, in girlspeak, the white piece. (haha)
Do you think I didn't do it right and that's what causing the fuse to blow?
Thanks again,
Monica
#4 Posted : Thursday, August 6, 2009 5:13:28 PM(UTC)
You probably did not adjust it properly. Follow the instructions from the Service manual and you should be fine.
MonicaDove
#5 Posted : Thursday, August 6, 2009 5:29:34 PM(UTC)
MonicaDove
Thanks, Gene! Ill let you know how goes.
MonicaDove
#6 Posted : Thursday, August 6, 2009 5:30:58 PM(UTC)
MonicaDove
Thanks, Gene. Ill let you know how it goes.
fuse on replacement washer lid switch assembly (Washer Repair)
by flmikee 12/25/2013 7:02:54 AM(UTC)
by dowsabel 12/17/2013 4:48:23 PM(UTC)
Maytag LAT5005AAE has new Lid Switch assembly but fuse continues to blow, what next? (Washer Repair)
by hankshiggs 2/1/2011 11:35:15 AM(UTC)
How To Install Lid Switch Assembly (Washer Repair)
by chucholoco6969 2/1/2011 9:30:55 AM(UTC)
Replacing lid switch assembly (Washer Repair)
by jboaz 1/24/2011 4:28:33 AM(UTC)
by kedo 9/30/2010 7:11:28 PM(UTC)
Whirlpool washer lid switch assembly (Washer Repair)
by Mailman83 6/24/2010 4:54:39 PM(UTC)
Replacing Lid Switch Assembly on Whirlpool washer (Washer Repair)
by DougH545 4/22/2010 8:12:19 AM(UTC)
Lid switch assembly (Washer Repair)
by rlpz@roadrunner.com 9/12/2009 10:29:39 AM(UTC)
