brevard_fl
#1 Posted : Tuesday, March 6, 2012 5:31:22 AM(UTC)
brevard_fl
It would seem to me a leak in evaporator or low pressure side, and low freon charge results in a few inches of vacuum when running, would pull air into system. a sort of self destructive behavior, is this true?
#2 Posted : Tuesday, March 6, 2012 6:41:10 AM(UTC)
That is correct, once the suction side goes below atmospheric pressure, it will suck in non-compressables that will damage a modern R134A compressor.
