The microwave in our GE dual microwave/wall oven blew. Repairman came and determined a relay was at fault, then shut off the breaker for the entire circuit without disconnecting the microwave. Will removing the 15-amp fuse in the microwave suffice in disconnecting it so I can turn the circuit back on and use the oven? Thanks!
Groups: APP Team
Joined: 2/12/2012(UTC) Views messages in topic : 5,556
Hi. Without the fuse your microwave should not have any power. Check if there is the light when the door is open.
When the microwave blew, everything quit working-- no light, no touchpad. Right after the it blew, though, the floor in the chamber got super hot, so I turned off the breaker. Before doing so, I checked the oven to ensure it was working and all was well with it. I'm just afraid if I turn the breaker back on to use the oven, something else will happen to the microwave. I'm hoping the fuse removal will solve my dilemma.
