lfranksathome
#1 Posted : Monday, March 5, 2012 10:49:47 AM(UTC)
lfranksathome
The microwave in our GE dual microwave/wall oven blew. Repairman came and determined a relay was at fault, then shut off the breaker for the entire circuit without disconnecting the microwave. Will removing the 15-amp fuse in the microwave suffice in disconnecting it so I can turn the circuit back on and use the oven? Thanks!
Simon / APP Team
#2 Posted : Monday, March 5, 2012 11:07:51 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Without the fuse your microwave should not have any power.
Check if there is the light when the door is open.
lfranksathome
#3 Posted : Monday, March 5, 2012 11:17:07 AM(UTC)
lfranksathome
When the microwave blew, everything quit working-- no light, no touchpad. Right after the it blew, though, the floor in the chamber got super hot, so I turned off the breaker. Before doing so, I checked the oven to ensure it was working and all was well with it. I'm just afraid if I turn the breaker back on to use the oven, something else will happen to the microwave. I'm hoping the fuse removal will solve my dilemma.
