The other day I Double oven clock went out Well we got the clock back on and I wans gettin error code F2 E1 well I have check the keypad connection I have now where the timer will work but I can't get any of the othere buttons to work What can I do to fix the problem? Thanks:rolleyes:
Most likely the control panel has to replaced. - The part number for the control panel assembly (black model) is AP3131918 - The part number for the control panel assembly (white model) is AP3131919 - The part number for the control panel (biscuit model) is AP3082514 Good luck. Gene.
