The large elect. element on the stove top sparked and tripped a breaker while boiling a large pot of water.
I found the short was the old burner, but when i plug in a new burner element it will only come on high no matter what the dial is set at. All the other burners work fine.
Any suggestions?
Brad C
Originally Posted by: btc  the large elect. element on the stove top sparked and tripped a breaker while boiling a large pot of water. i found the short was the old burner, but when i plug in a new burner element it will only come on high no matter what the dial is set at. all the other burners work fine. any suggestions? brad c brad, you need to replace that burner switch, and that will do it. tom
