BTC
#1 Posted : Tuesday, August 4, 2009 4:13:22 PM(UTC)
BTC
The large elect. element on the stove top sparked and tripped a breaker while boiling a large pot of water.
I found the short was the old burner, but when i plug in a new burner element it will only come on high no matter what the dial is set at.
All the other burners work fine.
Any suggestions?
Brad C
kayakcrzy
#2 Posted : Wednesday, August 5, 2009 4:53:34 AM(UTC)
kayakcrzy
Originally Posted by: btc Go to Quoted Post
the large elect. element on the stove top sparked and tripped a breaker while boiling a large pot of water.
i found the short was the old burner, but when i plug in a new burner element it will only come on high no matter what the dial is set at.
all the other burners work fine.
any suggestions?
brad c
brad, you need to replace that burner switch, and that will do it. tom
