There is a slow collection of clear water inside on the bottom of the unit. Saturates a few paper towels every day. First thought this was condensation due to hot humid weather but it continues to happen. I have looked for a drip but did not locate the source. Any ideas for where this is coming from and the cause?
Is it a side-by-side, top freezer or bottom freezer and where are you seeing the water. More than likely it is leaking because the drain is clogged. Refrigerator Leaking Repair Guide
It's a top freezer. The water is showing up under the vegetable drawers. Thanks for the repair guide. I will read through it.
