olddog
#1 Posted : Tuesday, August 4, 2009 11:10:44 AM(UTC)
olddog
There is a slow collection of clear water inside on the bottom of the unit. Saturates a few paper towels every day. First thought this was condensation due to hot humid weather but it continues to happen.
I have looked for a drip but did not locate the source. Any ideas for where this is coming from and the cause?
applianceman
#2 Posted : Tuesday, August 4, 2009 11:16:01 AM(UTC)
applianceman
Is it a side-by-side, top freezer or bottom freezer and where are you seeing the water. More than likely it is leaking because the drain is clogged. Refrigerator Leaking Repair Guide
olddog
#3 Posted : Tuesday, August 4, 2009 11:26:53 AM(UTC)
olddog
It's a top freezer. The water is showing up under the vegetable drawers. Thanks for the repair guide. I will read through it.
