pkula
#1 Posted : Sunday, March 4, 2012 10:45:03 AM(UTC)
pkula
I have a 14 year old Frigidaire refrigerator that the compressor was not energizing so i taped on the start/run relay and it started the compressor. It ran until the fridge was cooled to 30 degrees inside but the compressor would not stop so i adjusted the temp control switch to off and it shut off. I left the door open to see if the compressor would kick on again and it didn't so i disconnected the start/run relay from the compressor and found one (of the 3) power pins broken off from the compressor and lodged in the relay connector and showed signs of heat/burn. My question is it worth my time to replace the compressor and relay or simply junk the refrigerator all together?
Thank you,
Pat
#2 Posted : Monday, March 5, 2012 8:27:58 AM(UTC)
Way too expensive to fix. Next fridg, use a 1000 joule surge protector in the wall outlet, will prevent problems, or buy a GE fridg.
pkula
#3 Posted : Monday, March 5, 2012 8:37:34 AM(UTC)
pkula
Thank you for your reply Rich and advice. I agree!!
