jtown
#1 Posted : Saturday, March 3, 2012 3:30:30 PM(UTC)
jtown
Our washer leaks water but only sometimes.I haven't taken any panels off to see where the water is coming from but I was curious if anyone else has had this problem and what the problem is and what was done to correct it
Gary/APP Team
#2 Posted : Monday, March 5, 2012 1:53:48 PM(UTC)
mattt
Hello . This is what I find most of the time , when the complaint is sometimes it leaks, when you open the door , and look at the bottom of the glass door more than likely you will find a dirty spot , that needs to be cleaned, this usually will consist of some hair , that when you close the door, it sometimes will let it leak thru the bootAP4379904'); return false; " style="text-decoration:underline;" href ="http://www.appliancepartspros.com/partsearch.aspx?pn_=AP4379904" target="_blank">Part number: AP4379904
AP4379904" target="_blank"> AP4379904" border="0" alt="Part number: AP4379904" title="Part number: AP4379904">
AP4379904">
if it is clean you will need to check the door boot for a very small crack. Thank you and good luck !
Water Leaks in freezer AND refrigerator (Refrigerator & Freezer Repair)
by dgs1213 7/27/2015 10:47:56 AM(UTC)
Tub Fills But Water Leaks (Washer Repair)
by jcrance 10/7/2013 7:51:14 AM(UTC)
water leaks or splashes where fill tube meets icemaker and freezes below that area (Refrigerator & Freezer Repair)
by kwiknuts 5/5/2013 8:01:00 PM(UTC)
Ice build up in bottom of freezer, water leaks out door (Refrigerator & Freezer Repair)
by vidkid 5/10/2012 11:59:39 AM(UTC)
Water Leaks Under Door (Microwave Repair)
by simonteddy 12/2/2011 5:09:46 PM(UTC)
Water leaks on wash cycle (Washer Repair)
by Rimperio 9/26/2011 2:01:54 PM(UTC)
Water leaks over outer tub gasket (Washer Repair)
by tealbingy 6/30/2011 10:03:58 AM(UTC)
Water Leaks when no in use (Washer Repair)
by Gatito 6/14/2011 6:19:25 AM(UTC)
Freezer and Refrigerator to cold, water leaks (Refrigerator & Freezer Repair)
by renwa 11/1/2010 7:17:54 AM(UTC)
water leaks (Washer Repair)
by mj1003 3/30/2010 4:26:53 PM(UTC)
Water Leaks from front of dishwasher (Dishwasher Repair)
by jgordon051 2/27/2010 8:36:09 AM(UTC)
Water leaks when water is fed into the basin (Washer Repair)
by pmumola 11/14/2009 10:43:05 AM(UTC)
water leaks into tub when not turned on (Washer Repair)
by jstover 9/21/2009 1:37:39 PM(UTC)
Water Leaks Into Drum (Washer Repair)
by mjones823 7/14/2009 1:00:20 PM(UTC)
Water leaks into frig area (Refrigerator & Freezer Repair)
by Daniel Hir 7/14/2009 8:16:14 AM(UTC)
