Our washer leaks water but only sometimes.I haven't taken any panels off to see where the water is coming from but I was curious if anyone else has had this problem and what the problem is and what was done to correct it
Originally Posted by: jtown  Our washer leaks water but only sometimes.I haven't taken any panels off to see where the water is coming from but I was curious if anyone else has had this problem and what the problem is and what was done to correct it Hello . This is what I find most of the time , when the complaint is sometimes it leaks, when you open the door , and look at the bottom of the glass door more than likely you will find a dirty spot , that needs to be cleaned, this usually will consist of some hair , that when you close the door, it sometimes will let it leak thru the boot AP4379904'); return false; " style="text-decoration:underline;" href ="http://www.appliancepartspros.com/partsearch.aspx?pn_= AP4379904" target="_blank">Part number: AP4379904
AP4379904" border="0" alt="Part number: AP4379904" title="Part number: AP4379904">
AP4379904">
if it is clean you will need to check the door boot for a very small crack. Thank you and good luck !
