2 Pages<12
McAndrew11
#11 Posted : Monday, April 2, 2012 3:32:32 PM(UTC)
McAndrew11
I understand that. It burns initially then stops and does not reignite leaving the clothes damp at the end of a cycle.
Simon / APP Team
#12 Posted : Monday, April 2, 2012 5:19:17 PM(UTC)
Simon / APP Team
Groups: APP Team
Hello.
Let's fix your dryer.
I'd like you to check three things one by one.
Take the back off and locate the operating thermostat next to the fuse.
When the dryer start acting up install the jumper across two large contacts.
If that works - replace the thermostat.
If not - on the right locate the hi limit thermostat. Same procedure.
If that doesn't work - replace the flame sensor.
The hi-limit thermostat Part number: AP3084674
The operating thermostat Part number: AP3045874
The flame sensor Part number: AP2910747
Her are the breakdown diagrams and Replacement parts for Whirlpool LGB6400KQ1 DRYER | AppliancePartsPros.com
Good luck. Post the results.
Simon.
whirlpool dryer no heat (Dryer Repair)
Belarus dlctac 4/2/2012 10:07:47 AM(UTC)
Whirlpool Dryer no heat (Dryer Repair)
by gunworks 12/21/2011 4:03:17 PM(UTC)
by boyerjr 4/1/2011 12:44:44 PM(UTC)
whirlpool dryer no heat new everything (Dryer Repair)
by blainesr 1/6/2010 5:47:42 PM(UTC)
by donswife_1998 12/20/2009 5:54:00 PM(UTC)
by gary15f 7/3/2009 9:18:21 PM(UTC)
Whirlpool dryer no heat & timer wont shut off (Dryer Repair)
by lsaustin 6/20/2009 8:13:47 AM(UTC)
by looie 9/30/2008 11:51:43 AM(UTC)
2 Pages<12
