AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Maytag Neptune Combo Washer/ Dryer wont spin (washer)
:confused: Hello all, I'm having an issue with my Maytag MLG2000AWW Washer/ Dryer combo. Everything works fine with the washer and dryer except that the washer doesn't spin at the correct speed to remove the water from the clothes. The pump is fine because it drains the machine, the motor also functions correctly and the belt has tension. I'm a novice tinkerer but I did much more to troubleshoot the machine than the technician who charged $70 to tell me that the control board needed to be changed at the additional cost of $450 without even opening any of the access panels. I browsed through this site and found that others had changed the board and the machine continued to have the same problem. I would be forever grateful if someone can please assist me with some sound advise before I spend hundreds of dollars on trying to repair this unit. I feel comfortable and confident in swapping out defective electrical parts if needed to save hundreds of dollars. :(
Originally Posted by: HLSerrano  :confused: Hello all, I'm having an issue with my Maytag MLG2000AWW Washer/ Dryer combo. Everything works fine with the washer and dryer except that the washer doesn't spin at the correct speed to remove the water from the clothes. The pump is fine because it drains the machine, the motor also functions correctly and the belt has tension. I'm a novice tinkerer but I did much more to troubleshoot the machine than the technician who charged $70 to tell me that the control board needed to be changed at the additional cost of $450 without even opening any of the access panels. I browsed through this site and found that others had changed the board and the machine continued to have the same problem. I would be forever grateful if someone can please assist me with some sound advise before I spend hundreds of dollars on trying to repair this unit. I feel comfortable and confident in swapping out defective electrical parts if needed to save hundreds of dollars. :( HL, You're sure the washer spins, slowly, or is it tumbling back and forth ? and the door locks and the spin enable switch on the door latch assembly is closed and sending the circuit up to the control board. Do you have access to a multimeter Part number: AP3873826
To check circuits, wires and voltage. A place to start would be at the motor control board. Disconnect the JP4 connector(blue,red, yellow and two white wires) With a large needle or fine point awl, spread the metal contacts in the connector, and check for any frayed wires, and reattach the connector. Remove the washer top trim panel, on each side of the tub assembly, you'll find a multi plug, basically disconnect the harnesses, check the wiring and makes siure the pins and female connectors are a tight fit when you reattach the connectors. Then check and see if the washer will spin. Try this first, From there we'll need the multimeter and will need to access the washing machine control board, up inside the dryer cabinet in the right front corner, so we can check circuits and low voltage to the board. Thanks, :) :) :)
Hi I hope this post isnt too old to join..I have the exact same issue with the same machine EXCEPT My Model no. is MHW 2000 AWW I have been through the door switch and the selector dial ( The one that chooses the type of wash you want)I cleaned the terminals. Where can I find the control board? si it part of the motor control assembly? Stephen
Originally Posted by: sandmon@me.com  Hi I hope this post isnt too old to join..I have the exact same issue with the same machine EXCEPT My Model no. is MHW 2000 AWW I have been through the door switch and the selector dial ( The one that chooses the type of wash you want)I cleaned the terminals. Where can I find the control board? si it part of the motor control assembly? Stephen Stephen, Your washer, machine control board, Part number: AP4027830
Is located in the front, top right corner, of the dryer cabinet, you'll need to remove the dryer front panel and door assembly to access it. As mentioned in the previous posts, you want to check as many components and circuits as possible, with a multimeter, especially the molex connectors mounted on the sides of the tub, before you go up to the control board(unless the door is not locking, Then start at the control board and check for a damaged, burnt R11 resistor). Thanks and Good Luck,
As it turns out, I had a bad connection on the lower tub displacement switch. Easy as pie an the first thing i cheched after the door/spin switches Ill recommmend you to everyone!
Stephen
Originally Posted by: sandmon@me.com  As it turns out, I had a bad connection on the lower tub displacement switch. Easy as pie an the first thing i cheched after the door/spin switches Ill recommmend you to everyone!
Stephen Stephen, Great job. We're glad for you, a nice easy check and repair. Thanks for the update and the support. Thanks Again,
Washer Repair
