cbradshaw8@sc.rr.com
#1 Posted : Monday, August 3, 2009 1:53:36 PM(UTC)
The dryer heats but does not remove all the water from the clothes. It takes several drying cycles to completely dry the clothes. The drum runs and the heating element heats but does not remove the water from clothes. It may take 2 hours to dry sheets. Any suggestions???
#2 Posted : Tuesday, August 4, 2009 12:18:24 PM(UTC)
Most likely the problem is an insufficient air flow through the dryer and/or the vent. Make sure the vent is absolutely clean all the way through the outlet. Disassemble the dryer and clean all air ducts inside. Check the blower wheel.
Here are the breakdown diagrams and Replacement parts for GE DBXR453EV1WW | AppliancePartsPros.com
GE Dryer won't stay on (Dryer Repair)
by Guest 6/21/2024 2:16:20 PM(UTC)
Ge dryer will not stay on (Dryer Repair)
by Guest 5/10/2024 3:25:16 PM(UTC)
GE dryer timer issue (Dryer Repair)
by Guest 5/8/2024 11:47:16 AM(UTC)
GE Dryer Timer and Housing (Dryer Repair)
by Guest 3/25/2024 7:47:59 AM(UTC)
Humming/Rattle After Blower Wheel Replacement - GE Dryer (Dryer Repair)
by PISCDryer 11/8/2023 7:10:25 AM(UTC)
GE Dryer Not Heating - Model: GFDS140ED0WW (Dryer Repair)
by laflair13 3/1/2023 3:14:27 AM(UTC)
GFD55ESSN0WW GE Dryer stays on Pause when I press start (Dryer Repair)
by Guest 6/8/2022 6:54:15 AM(UTC)
No power or panel lights to GE Dryer (Dryer Repair)
by Guest 4/1/2022 4:03:52 PM(UTC)
No panel lights GE Dryer (Dryer Repair)
by Guest 4/1/2022 4:00:44 PM(UTC)
GE Dryer Model DWSR483EG9WW Squeaky & Loud (Dryer Repair)
by pdl2 12/23/2021 12:10:27 PM(UTC)
Gas GE dryer (Dryer Repair)
by Guest 6/20/2021 10:17:53 AM(UTC)
GE DRYER PART INTERCHANGEABLE (Dryer Repair)
by Guest 3/27/2021 12:02:09 PM(UTC)
GE dryer keeps pausing (Dryer Repair)
by ffltstn 3/23/2021 7:15:37 AM(UTC)
Will my GE Dryer still work (Dryer Repair)
by JW Appliance 1/29/2021 11:07:33 AM(UTC)
Trying to replace a GE dryer motor (Dryer Repair)
by Gigs34 9/8/2020 9:59:46 AM(UTC)
