hkelman
#1 Posted : 16 years ago
hkelman
The black plastic control panel part #8302848 Black is cracked.:( I purchased a replacement part and have it in hand. I cannot figure out how to remove the existing control panel in order to replace it. :confused: I have already removed the two side trim strips from the oven.
Do I need to remove the oven from the wall? Do you have a diagram and/or instructions that show how to access the fasteners and remove the panel?
Thank you for any and all help you can give.
Harold
Will1161
#2 Posted : 16 years ago
Will1161
Harold
I am experiencing the same dilema, I have a model GBD307PRB00, I would greatly appreciate any instructions,
Thanks in advance,
Will
hkelman
#3 Posted : 16 years ago
hkelman
:D Off another forum I received instructions. Had to pull the oven out of the wall. Remove the side strips, then screws at the top of the oven behind the control panel to remove the entire control panel. Screws at the back of the control panel hold the plastic trim onto the electronic panel. Be careful to note how it all fits together so you can get it back in later. I was able to do it all without disconnecting any cables. Had trouble putting the unit back into the wall because some debris got on the supports under the oven but was able to get it in and all works fine and looks good now
Lifterfe
#4 Posted : 14 years ago
Lifterfe
What forum? I have a different Model # but the parts illustration looks the same as it does for your Model. I don't want to take the whole oven out of the wall though!
Whirlpool Wall Oven control panel issues (Oven Repair (including Ranges and Cooktops))
by spkolluri 14 years ago
