AppliancePartsPros.com
Appliance Repair Help
Washer Repair
ge washer won't spin or wash, no blinking lights on motor
The schematic says to count the blinking lights (red or green) but there are no lights blinking on top of the motor.
Check out the fuse that is in the wire running down the right side of the washer. If the motor is getting power though you will need to replace it (the flashing lights are on an inverter which is part of the motor assembly)
Originally Posted by: sidfink43  Check out the fuse that is in the wire running down the right side of the washer. If the motor is getting power though you will need to replace it (the flashing lights are on an inverter which is part of the motor assembly) Thanks! I guess the motor is bad.
Probably the inverter but it is a part of the motor and not a separate repair item.
If you order from this site and the part does not fix the problem you can return it, see the returns policy.
Washer Repair
