fr45
#1 Posted : Tuesday, February 28, 2012 9:22:19 AM(UTC)
fr45
The schematic says to count the blinking lights (red or green) but there are no lights blinking on top of the motor.
sidfink43
#2 Posted : Wednesday, February 29, 2012 5:12:48 PM(UTC)
sidfink43
Check out the fuse that is in the wire running down the right side of the washer. If the motor is getting power though you will need to replace it (the flashing lights are on an inverter which is part of the motor assembly)
fr45
#3 Posted : Thursday, March 1, 2012 8:41:53 AM(UTC)
fr45
Thanks! I guess the motor is bad.
sidfink43
#4 Posted : Thursday, March 1, 2012 9:15:49 AM(UTC)
sidfink43
Probably the inverter but it is a part of the motor and not a separate repair item.
If you order from this site and the part does not fix the problem you can return it, see the returns policy.
