13 month old maytag front load washer model # MHWE200XW00 is out of warranty. I have excellent water supply going into the unit. The unit seems to work at all functions except the drum will not spin. The unit shuts down after 6-7 minutes and displays an error code F7 and F1. The unit fills with water and then the drum starts to spin 1-2 very slow times and then stops the unit proceeds thruogh the cycle, rinse, drain, etc. and shuts down after 6-7 minutes. The drum will not spin, belt is good. Is this a water level pressure switch issue or could such a new unit have greater issues? Thanks, Mike.
The unit will not agitate either.
door not locking and not spinning or extracting the water from the clothes.. hope it is not the circuit board...too expensive to fix.
Maytag front loader door locks only and displays F21
