tmichael
#1 Posted : 13 years ago
tmichael
13 month old maytag front load washer model # MHWE200XW00 is out of warranty. I have excellent water supply going into the unit. The unit seems to work at all functions except the drum will not spin. The unit shuts down after 6-7 minutes and displays an error code F7 and F1. The unit fills with water and then the drum starts to spin 1-2 very slow times and then stops the unit proceeds thruogh the cycle, rinse, drain, etc. and shuts down after 6-7 minutes. The drum will not spin, belt is good. Is this a water level pressure switch issue or could such a new unit have greater issues? Thanks, Mike.
tmichael
#2 Posted : 13 years ago
tmichael
The unit will not agitate either.
thadrow
#3 Posted : 13 years ago
thadrow
door not locking and not spinning or extracting the water from the clothes..
hope it is not the circuit board...too expensive to fix.
Georgewbushus1
#4 Posted : 12 years ago
Georgewbushus1
Maytag front loader door locks only and displays F21
