I`am waiting on Sears Canada to send a new defrost thermostat. Can I still operate the refigerator ? Seems to be working fine.
The unit will work fine,Until it trys to defrost. If you connected the 2 wires together, It will defrost, if you just taped them up(but not together) It will NOT defrost!!!! After a couple of days, the unit will frost-up and stop cooling!!! The defrost thermostat is a SAFTEY DEVICE!!!! DO NOT run the unit for a long period of time without it!!!!!!!:)
