The dryer will not start and I've checked the continuity to the switch at the control panel and the door switch and both are good. I have also checked the outlet for voltage and the terminal that the cord attaches to and there is voltage. Is there anything else I can check that would cause the dryer not to start?
Thank you!
Take off the back and check the thermal fuses/thermostats, particularly these two suckers for continuity Part number: AP3094224
Oh, and while you are back there clean it all out, particulary the blower. Good hunting
