AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Gas dryer not heating up at all, just tumbles.
The every first symptom was it takes much longer to dry a normal load. Now it just tumbles and no heat at all. I checked the continuity of the thermal fuse and it's good. Checked the adjustable cycling thermostat and that's good. Checked the normal thermostat and it show "open". Also checked the heat sensor that attached to the back of what looks like a heat chute. That checked out fine. I'd also replaced the main and secondary coils thinking that was the cause. Did I miss anything else to check or do you think the normal thermostat is the main culprit.
TIA, Richard
bump to the top someone help if you can please
Dryer Repair
