looz98
#1 Posted : Monday, July 27, 2009 5:05:07 AM(UTC)
looz98
? ...when the compressor is running shouldn't the fan also be running to pull heat away from compressor, or does it work on a thermostat that turns fan on only when temp of compressor gets to hot? if not what might the problem be with the fan as it seems to run sporadically.
#2 Posted : Monday, July 27, 2009 5:20:09 PM(UTC)
The condenser fan motor (next to the compressor) must run together with the compressor. If it does not then check for 120 VAC to the motor. If there is nothing wrong - replace the motor.
- The condenser fan motor Part number: AP3120994
Here are the breakdown diagrams and Replacement parts for AMANA TR21S4L | AppliancePartsPros.com
looz98
#3 Posted : Monday, July 27, 2009 5:26:02 PM(UTC)
looz98
thanks gene
#4 Posted : Monday, July 27, 2009 5:34:22 PM(UTC)
looz98
#5 Posted : Wednesday, August 5, 2009 4:12:16 AM(UTC)
looz98
gene..fan was an easy fix ,all went well ...one quick ? about your thoughts on whirlpool cabrio washer and dryer...how would you rate them for reliabilty?
thanks
looz98
#6 Posted : Friday, August 7, 2009 5:16:39 PM(UTC)
Originally Posted by: looz98 Go to Quoted Post
...about your thoughts on whirlpool cabrio washer and dryer...how would you rate them for reliabilty?...
I would rate them probably 6.5 out of 10 just because of over computerized. You can see a lot of advertisements about their power and water efficiency. Unfortunately they will never last long enough to let you see it.
mikeal21
#7 Posted : Friday, August 7, 2009 8:47:31 PM(UTC)
mikeal21
Will this motor work for my Amana side by side model # SCD23VW ?
I'm having same problem and possibly others. But the other day I looked and temp in freezer was 10F or more. Gave the fan a push and it started up. The temp then went back down shortly there after. Any help would be greatly appreciated.......
#8 Posted : Sunday, August 9, 2009 8:48:50 PM(UTC)
Yes, you can use the same motor.
mikeal21
#9 Posted : Wednesday, August 12, 2009 4:21:38 AM(UTC)
mikeal21
Easier than I would have thought. Great price, economy shipping was great also, still only took 2 days to receive part.....
Gotta update my bookmarks for this website :D .........
#10 Posted : Wednesday, August 12, 2009 2:48:48 PM(UTC)
I'm glad you were able to fix it. Thank you for the good words and for your feed back.
