? ...when the compressor is running shouldn't the fan also be running to pull heat away from compressor, or does it work on a thermostat that turns fan on only when temp of compressor gets to hot? if not what might the problem be with the fan as it seems to run sporadically.
The condenser fan motor (next to the compressor) must run together with the compressor. If it does not then check for 120 VAC to the motor. If there is nothing wrong - replace the motor. - The condenser fan motor Part number: AP3120994
gene..fan was an easy fix ,all went well ...one quick ? about your thoughts on whirlpool cabrio washer and dryer...how would you rate them for reliabilty? thanks looz98
Originally Posted by: looz98  ...about your thoughts on whirlpool cabrio washer and dryer...how would you rate them for reliabilty?... I would rate them probably 6.5 out of 10 just because of over computerized. You can see a lot of advertisements about their power and water efficiency. Unfortunately they will never last long enough to let you see it. Gene.
Originally Posted by: Gene  The condenser fan motor (next to the compressor) must run together with the compressor. If it does not then check for 120 VAC to the motor. If there is nothing wrong - replace the motor. - The condenser fan motor Part number: AP3120994
Will this motor work for my Amana side by side model # SCD23VW ? I'm having same problem and possibly others. But the other day I looked and temp in freezer was 10F or more. Gave the fan a push and it started up. The temp then went back down shortly there after. Any help would be greatly appreciated.......
Originally Posted by: mikeal21  Will this motor work for my Amana side by side model # SCD23VW ? I'm having same problem and possibly others. But the other day I looked and temp in freezer was 10F or more. Gave the fan a push and it started up. The temp then went back down shortly there after. Any help would be greatly appreciated....... Yes, you can use the same motor. Gene.
Originally Posted by: Gene  Yes, you can use the same motor.
Gene. Easier than I would have thought. Great price, economy shipping was great also, still only took 2 days to receive part..... Gotta update my bookmarks for this website :D .........
I'm glad you were able to fix it. Thank you for the good words and for your feed back.
