nospin
#1 Posted : Saturday, January 5, 2008 4:31:49 PM(UTC)
nospin
My electric dryer stopped mid cycle and will not restart. When the timer is set you can still hear it running and when the door is opened the light does not come on. I have checked the bulb and it is good. If the door switch is bad would the light remain of or come on. In other words does the door switch fail in the door open position. Would the thermal fuse affect the door light?
#2 Posted : Sunday, January 6, 2008 4:09:02 PM(UTC)
Groups ready for retrieval: Senior Expert, Administrators
The first thing I would check is the thermal fuse. It is located on the heater box. If it's open - it has to be replaced together with the hi limit thermostat.
If there is nothing wrong with the thermal fuse, then check the door switch. It has three terminals: common (COM), normally open (NO) and normally closed (NC). Remove the wire from the common (COM) terminal and check continuity across the COM and the NO and the COM and the NC with the door open and closed.
The readings should be:
1. The door open : COM & NO - ∞ Ohms, COM & NC - 0 Ohms;
2. The door closed: COM & NO - 0 Ohms, COM & NC - ∞ Ohms.
- The part number for the thermal fuse kit is AP415996
- The part number for the door switch is AP311176
Good luck.
nospin
#3 Posted : Sunday, January 6, 2008 4:38:26 PM(UTC)
nospin
Thanks Gene. I located the thermal fuse on the lower right side of the heater box and jumped it momentarily and everything worked. WIll order the parts tonight. Thank you again for your help.
Dryer does not spin (Dryer Repair)
by shareefhart 3/6/2010 12:43:22 PM(UTC)
