nickspal
#1 Posted : Saturday, July 25, 2009 9:07:53 AM(UTC)
nickspal
The water temp is warm not hot. How do I check if it is the thermistat or the heating element.
magician59
#2 Posted : Saturday, July 25, 2009 1:12:26 PM(UTC)
magician59
Check the temperature of the hot water at your sink. You need at least 120 degrees F.
nickspal
#3 Posted : Monday, July 27, 2009 12:20:48 PM(UTC)
nickspal
The water temp at the sink is 135 degrees
magician59
#4 Posted : Monday, July 27, 2009 2:08:54 PM(UTC)
magician59
You may need to uninstall the machine and tip it on its side or back (side only if Bosch) to access the terminals of the heating element. Check for continuity by removing one of the wire connectors. If no continuity, replace it. Easy to replace. loosen nuts at terminals and whatever clips on the inside of the tub.You'll need to consult your tech sheet to see if thermostat or thermistor.
