dlaroche1
#1 Posted : Saturday, July 25, 2009 6:52:14 AM(UTC)
dlaroche1
The motor will start and run, but stops when you let go of the start switch. I cannot hear the timer motor running. The door switch turns the drum light on and off so I asume it is working. I have a multimeter and could probably find my way through the wiring diagram, but any info would be appreciated.
#2 Posted : Saturday, July 25, 2009 12:50:06 PM(UTC)
I would check for a bad belt break switch AP3994765 on the bottom of the dryer, or a bad motor AP2043550, just check motor per the service sheet.
Dryer wont stay on (Dryer Repair)
by pmsage 1/20/2013 9:26:20 AM(UTC)
dryer wont stay on (Dryer Repair)
by LGRANDE 6/14/2012 4:11:11 PM(UTC)
