The motor will start and run, but stops when you let go of the start switch. I cannot hear the timer motor running. The door switch turns the drum light on and off so I asume it is working. I have a multimeter and could probably find my way through the wiring diagram, but any info would be appreciated.
I would check for a bad belt break switch AP3994765 on the bottom of the dryer, or a bad motor AP2043550, just check motor per the service sheet.
