Dianne
#1 Posted : Saturday, January 5, 2008 7:19:45 AM(UTC)
Dianne
My disposal is locked and the reset button does not release it. I have a tool for the disposal (a "Z" like tool??) but I cannot find how this might help. Any suggestions? thank you ~
kooler
#2 Posted : Monday, February 11, 2008 12:45:38 PM(UTC)
kooler
Hey Dianne, you should be able to look underneath the disposer and in the exact center locate where the tool can be inserted to manually move the disposer motor in either direction and hopefully dislodge whatever it is that has it locked up... Be mindful not to energize the disposer with this tool inserted in place and especially careful if you have to fish around inside the disposer to remove the culprit... cheers, kooler
hena
#3 Posted : Saturday, February 13, 2010 10:12:04 AM(UTC)
hena
Dianne, I have used a old broom handle in the past to gently tap the fins inside the unit. Try tapping both directions and this should free whatever is blocking the unit from working.Remember to do this with the unit off and never, ever insert your hands into the disposer!
Good luck
JOE
Garbage disposal not working (Garbage Disposer Repair)
by Guest 9/25/2021 4:06:35 AM(UTC)
New Garbage Disposal sparks underneath when switch is thrown (Garbage Disposer Repair)
by john flavia 12/14/2015 8:05:13 AM(UTC)
leaking garbage disposal (Garbage Disposer Repair)
by gesche444 8/11/2014 3:23:39 PM(UTC)
Monarch Garbage Disposal (Garbage Disposer Repair)
by willie2840 7/20/2013 1:40:26 PM(UTC)
GE garbage disposal jammed from potato skins (Garbage Disposer Repair)
by Clifford_boyson_iowa 1/9/2013 8:47:55 PM(UTC)
Garbage Disposal not closing (Garbage Disposer Repair)
by avidteacher1 6/26/2012 8:41:42 AM(UTC)
by jakester3 6/12/2012 5:43:27 PM(UTC)
Leaking Garbage Disposal (Garbage Disposer Repair)
by newelldj2 4/9/2012 12:40:32 PM(UTC)
garbage disposal died - won't do anything (Garbage Disposer Repair)
by mindiloo 1/31/2012 5:36:42 PM(UTC)
Stuck garbage disposal (Garbage Disposer Repair)
by DonnieMo 1/7/2012 11:24:18 AM(UTC)
Garbage disposal leaking at yhe boiiom when water is turned on (Garbage Disposer Repair)
by dsloss1 11/13/2011 11:47:44 AM(UTC)
Garbage disposal problem (Garbage Disposer Repair)
by jnfica 7/21/2011 7:19:58 PM(UTC)
Leaky garbage disposal (Garbage Disposer Repair)
by Tippsy 6/22/2011 4:59:19 AM(UTC)
garbage disposals (Garbage Disposer Repair)
by shelterpup 1/4/2011 7:42:39 PM(UTC)
kenmore garbage disposal internal leak (Garbage Disposer Repair)
by bill5506 12/27/2009 8:12:02 AM(UTC)
