Samhill
#1 Posted : Thursday, July 23, 2009 5:37:41 AM(UTC)
Samhill
GE Refrigerator/ Old style Ice Maker. I ahve replaced the water valve and selenoid. Water to the door. Ice maker still not working. When front control panel activated for water I get 130V at the selenoid. When the arm from the Ice amker calls for water I do not get voltage at the selenoid. Where do I check this next?
#2 Posted : Thursday, July 23, 2009 2:37:04 PM(UTC)
What is the complete model number of the refrigerator?
Which solenoid did you replace? What is not working: the ice maker or the ice dispenser?
Samhill
#3 Posted : Thursday, July 23, 2009 3:44:49 PM(UTC)
Samhill
Gene,
The only model number I have is TFX25CR. I know that is not complete but is all I can find. I replaced the water valve kit at the bottom rear of the unit where the water line connects. (entire unit). I also replaced the entire ice maker with a universal GE replacement part. Still no ice. I did test the electrical connections on the water valve and found that when I push the door control for water that I have a 130v on the selenoid of the replaced water valve. However I have no voltage on the other selenoid which I believe controls the ice maker portion. I have tested with the control arm of the ice maker in all positions. You can hear it trying from time to time but there is no water flowing into the ice maker. Not sure where to go from here.
Pete
#4 Posted : Thursday, July 23, 2009 4:43:00 PM(UTC)
Pete,
Make sure the water feeding tube into the ice maker is not frozen or blocked.
Swap the wires on the water valve. Push the ice cube release on the dispenser and see if the ice maker got water.
Post the results.
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 5/15/2024 4:30:46 AM(UTC)
GE side by side refrigerator freezer not cooling (Refrigerator & Freezer Repair)
by ReddogRudy 6/10/2018 3:21:06 PM(UTC)
GE side by side refrigerator not holding temperature (Refrigerator & Freezer Repair)
by Jmatthew33 7/8/2014 8:06:56 PM(UTC)
Power coupling/ power line harness. GE side by side refrigerator. (Refrigerator & Freezer Repair)
by Skully2014 7/24/2013 12:00:57 PM(UTC)
GE side by side refrigerator/freezer (Refrigerator & Freezer Repair)
by Mprior 4/27/2011 9:16:06 AM(UTC)
GE Side by Side Refrigerator (Refrigerator & Freezer Repair)
by trimbo 3/23/2011 11:26:12 AM(UTC)
GE side by side refrigerator both temp show 75 degree help (Refrigerator & Freezer Repair)
by lucky_me 2/6/2010 12:57:39 AM(UTC)
GE side by side refrigerator dispensor dripping (Refrigerator & Freezer Repair)
by mjl 7/19/2009 6:32:44 PM(UTC)
GE side by side refrigerator not dispensing ice (Refrigerator & Freezer Repair)
by philly09 4/21/2009 3:14:48 PM(UTC)
by shirleymillan 3/12/2009 5:33:43 PM(UTC)
ice shoot flap won't close on ge side by side refrigerator (Refrigerator & Freezer Repair)
by amyp 10/23/2007 6:34:51 AM(UTC)
