kaveman1
#1 Posted : Sunday, February 12, 2012 6:29:24 AM(UTC)
kaveman1
clicking noise from compressor replaced starter but not capacitor still just clicking and getting hot can I test the capacitor before buying a new one
#2 Posted : Monday, February 13, 2012 5:15:25 AM(UTC)
There is no reliable way to test the capacitor as often they only breakdown when working voltage (120 volts) is applied to them and your meter cannot supply that voltage.
You can check the capacitor to see if it is a dead short or open.
Use a number of different meter scales when doing this.
Also you must short the capacitor leads together between each measurement.
If it is OK at the meter voltage you will see the resistance rise as the capacitor charges.
You may see weird stuff as the capacitor is a non polarized electrolytic.
Here is a link about capacitors probably a lot more than you need or want but I thought I would include is as general info.
http://www.repairfaq.org/sam/captest.htm
You could check the compressor, the below is a good site on how to do this
How To Fix a Refrigerator - Appliance Repair Guide - ACME HOW TO.com
Note: if it checks out OK electrically it may still be the problem due to mechanical problems.
Frigidaire not cooling (Refrigerator & Freezer Repair)
by shel112360 9/23/2015 5:34:06 PM(UTC)
FRIGIDAIRE not cooling enough (Refrigerator & Freezer Repair)
by SHOOTER468 9/22/2014 6:29:18 AM(UTC)
Frigidaire Not Cooling (Refrigerator & Freezer Repair)
by Mr H 4/3/2013 4:28:29 PM(UTC)
Frigidaire not cooling evenly (Refrigerator & Freezer Repair)
by wattsk69 8/27/2012 10:54:54 PM(UTC)
frigidaire not cooling properly (Refrigerator & Freezer Repair)
by colusapaul 5/16/2012 8:25:41 AM(UTC)
by ereichard 4/3/2012 9:52:46 AM(UTC)
Frigidaire not Cooling (Refrigerator & Freezer Repair)
by RHolmes 2/8/2012 1:56:04 PM(UTC)
Frigidaire not cooling well (Refrigerator & Freezer Repair)
by dvjorge 8/19/2011 5:01:24 PM(UTC)
1.5 YEAR OLD frigidaire not cooling anymore!!!!! PLEASE HELP! (Refrigerator & Freezer Repair)
by sssb2000 6/30/2010 3:13:12 PM(UTC)
by Judwyn 3/11/2010 12:32:20 PM(UTC)
