It stopped working/cooling both the fridge and the freezer. NO warranty cause it's more than a year old. The temp in the fridge is 71 now, and the freezer 62. filter looks clean.....i've unplugged it and back again.....i've reset the temp, etc. please see attached pictures from the bottom of the back of the fridge. (the blue thing on the bottom ride hand side is now leaking a drop or two....i tried to tighten it but it made it a bit worse so i put a bucket under it.) Please help! sssb2000 attached the following image(s):
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  thanks for the links. yes, it's not working as in it doesn't keep the temp down. The fridge seems to be "running", however, the freezer is as cold as the fridge should be, and the fridge is...well....room temp. lol (maybe a bit cooler). can you or someone else identify the components in the pictures i posted? i don't know what things are and that makes it a bit difficult to diagnose. we called the place that it was bought, and they said, nope, just one year. i called the manufacturer directly, and they wouldn't even help cause it was manufactured more than 2 years ago!
