garyg53
#1 Posted : Saturday, February 11, 2012 12:46:14 PM(UTC)
garyg53
I have a sears series 110 washer that will agitate while spinning and will not spin when loaded. the lid switch went out so I bypassed it by connecting the white and gray wires. any suggestions to solve this problem
hoosierdade
#2 Posted : Saturday, February 11, 2012 7:07:09 PM(UTC)
hoosierdade
it sounds like the clutch lining is bad. It's not that hard to replace and it cost about $30.00. Easy fix. Just make sure that you put the right tension springs back in. (The same color that you pulled out)
garyg53
#3 Posted : Saturday, February 11, 2012 9:16:12 PM(UTC)
garyg53
thank you it sounds like a good possibility will check it out
