AppliancePartsPros.com
Appliance Repair Help
Washer Repair
washing machine will not spin when loaded but does when empty
I have a sears series 110 washer that will agitate while spinning and will not spin when loaded. the lid switch went out so I bypassed it by connecting the white and gray wires. any suggestions to solve this problem
it sounds like the clutch lining is bad. It's not that hard to replace and it cost about $30.00. Easy fix. Just make sure that you put the right tension springs back in. (The same color that you pulled out)
thank you it sounds like a good possibility will check it out
Washer Repair
