RHolmes
#1 Posted : Wednesday, February 8, 2012 1:56:04 PM(UTC)
RHolmes
Our Refrigerator has stopped cooling. Where would you suggest starting to look. I have cleaned the coils and everything looks good. The compressor runs fine but does not cut off.
PLRU1777DSO Serial number WA50400486 Frigidaire
#2 Posted : Thursday, February 9, 2012 7:04:25 AM(UTC)
Replacement parts for PLRU1777DSO models | AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/p...df/StCloud/297005300.pdf
First check to be sure the compressor is running.
You can usually hear it but it should also be warm and you should feel it vibrating.
If it is on check that the compressor/condenser fan is running.
Check that the evaporator/fridge fan is running.
If all OK, remove the cover inside the fridge so you can inspect the evaporator coils.
If they are heavily frosted/iced over then you have a defrost problem.
If there is no frost or just frost in one area, usually where the freon enters the coils, then you have a sealed system problem.
This will be an expensive repair as you will need a pro and often it makes more sense to put those dollars towards a new unit.
Frigidaire not cooling (Refrigerator & Freezer Repair)
by shel112360 9/23/2015 5:34:06 PM(UTC)
FRIGIDAIRE not cooling enough (Refrigerator & Freezer Repair)
by SHOOTER468 9/22/2014 6:29:18 AM(UTC)
Frigidaire Not Cooling (Refrigerator & Freezer Repair)
by Mr H 4/3/2013 4:28:29 PM(UTC)
Frigidaire not cooling evenly (Refrigerator & Freezer Repair)
by wattsk69 8/27/2012 10:54:54 PM(UTC)
frigidaire not cooling properly (Refrigerator & Freezer Repair)
by colusapaul 5/16/2012 8:25:41 AM(UTC)
by ereichard 4/3/2012 9:52:46 AM(UTC)
frigidaire not cooling (Refrigerator & Freezer Repair)
by kaveman1 2/12/2012 6:29:24 AM(UTC)
Frigidaire not cooling well (Refrigerator & Freezer Repair)
by dvjorge 8/19/2011 5:01:24 PM(UTC)
1.5 YEAR OLD frigidaire not cooling anymore!!!!! PLEASE HELP! (Refrigerator & Freezer Repair)
Belarus sssb2000 6/30/2010 3:13:12 PM(UTC)
by Judwyn 3/11/2010 12:32:20 PM(UTC)
