My refrigerator is about 9yrs.old. For about 2 weeks now water has been accumalating in bottom,under vegetable drawers. Every 3-4 days I have to soak it up. Any suggestions? Jim:eek:
Originally Posted by: jim  My refrigerator is about 9yrs.old. For about 2 weeks now water has been accumalating in bottom,under vegetable drawers. Every 3-4 days I have to soak it up. Any suggestions? Jim:eek: Sounds like the drain is clogged up. Check at bottom of unit, may have to remove the kick plate or access from back side of unit, where the drain hose runs to a pan. Try with a soft wire to unclogg. Careful not to split the drain hase though. Best of Luck.
