vern51
#1 Posted : Saturday, July 18, 2009 7:05:51 PM(UTC)
vern51
My dryer sqeaks when I first start it, then it quits. Is it the belt, idler pulley, etc? it's ten years old. Other than this problem it works just fine. I would like to order the right part/s the first time.
sidfink43
#2 Posted : Sunday, July 19, 2009 1:56:41 PM(UTC)
sidfink43
Hi Vern
I would replace the belt, idler assembly and support rollers. These parts are not expensive and this should keep you going for a pretty long time. One of them will probably stop your noise, but you might as well do a complete job, and then be done with it.
Good luck
hdustoff40
#3 Posted : Monday, February 8, 2010 3:24:39 PM(UTC)
hdustoff40
Maytag Performa dryer Model #MDE2300AYW squeals when you start it up and sometimes during the cycle. How Do I fix it.
sidfink43
#4 Posted : Monday, February 8, 2010 4:56:07 PM(UTC)
sidfink43
Same answer
