joedylewski
#1 Posted : Saturday, February 4, 2012 12:55:51 PM(UTC)
joedylewski
Unable to drain washer in spin cycle. Checked hoses and replaced pump but still doesn't work
sidfink43
#2 Posted : Monday, February 6, 2012 5:05:30 PM(UTC)
sidfink43
Operate it with the front panel off and see if you can see what is happening during the spin cycle with the belt that is on the pump. If it is turning then there may be an obstruction in the hoses somewhere that you have not been able to find.
joedylewski
#3 Posted : Sunday, February 12, 2012 6:41:45 AM(UTC)
joedylewski
Thanks. Found sock blocking the exit site from tub. Machinee working welll
sidfink43
#4 Posted : Sunday, February 12, 2012 8:21:31 AM(UTC)
sidfink43
Great, glad you found that and thanks for updating us.
Maytag washer won't drain with clothes (Washer Repair)
by Guest 7/8/2021 3:20:36 PM(UTC)
Maytag washer won't drain water after cycle ends (Washer Repair)
by jasper7821 3/6/2015 11:26:44 AM(UTC)
Maytag washer won't drain (Washer Repair)
by andy65 3/29/2012 1:18:18 PM(UTC)
Maytag Washer won't drain when it comes to 'spin' cycle (Washer Repair)
by andyjmatthews 8/14/2011 5:01:17 PM(UTC)
Belarus jim.davis4000 4/5/2011 12:02:46 PM(UTC)
Maytag Washer Won't Drain or Stop Cycling (Washer Repair)
by bardo99 5/11/2010 8:59:06 AM(UTC)
Maytag washer won't drain before spin cycle (Washer Repair)
by marklyn 2/24/2009 3:51:22 PM(UTC)
Maytag Washer won't drain (Washer Repair)
by J Tillmanns 10/7/2007 11:43:12 AM(UTC)
