I replaced the defrost timer and 3-4 days later the coils were iced up. The fridge part was warm. I manually turned the defrost timer to defrost; 25 minutes later the refrigerator re-started. As I suspected, the timer motor was not running when the compressor was running, only when it is in the defrost mode. Can you help?
George 10:D
Im having the same problem with my amana.
Mark the timer knob and housing to verify timer not turning, you might have ordered the wrong timer.
