Hi, my top load washer does not wash anymore, it will spin and drain but how can i find the problem?
Hi Senteya
First take off the agitator and inspect the block at the top to make sure it is ok.
If the agitator is not the problem, take off the front panel and try to turn the pulley on the transmission shaft. If it does not turn you have a bad transmission.
If it is free, operate the machine with the front panel off and see if the motor is turning during the agitation cycle.
Let us know what you learn.
