I have a Frigidaire 8 Cycle Flex Care washer that would not agitate or spin. I have replaced the belt and check the lid switch. The pulley under the motor spins but the other two pulleys do not spin. What could be the problem?
I think your transmission is jammed and given the age of the machine a replacement is probably in order.
You got 10+ years use of the washer, that's very good.
